Sections Won't Update
dgschaefer
Creo Parametric 2.0, M060
I have some fasteners in my assembly that I replaced with a longer version from the same family table.  I had the section through one of them active when I replaced them. After replacing, the section was no longer active.  I re-activated the section but it still shows the old fastener with the new ghosted as if it were a surface model (see screen shot below).
I tried deactivating and reactivating teh section and regenerating the assembly, no change.
How do I fix this?
LinkedIn
Doug, I am seeing what you are saying with a model I am working with right now.
I have these ghost surfaces floating around from features I am tweaking into shape. Very annoying!
I thought I remembered CS saying this was resolved by M060? I am still on M040 and it is a very pervasive problem.
Toggling the cap in by editing the section seems to "regen" the section.
What if you close the part and erase not displayed? Seems you are having family table problems.
The parts themselves display properly on their own.  No issues with the part family table at all that I can see.  There is no family table in the assy.
The problem eventually resolves itself, but I'm not sure how.  It's as if Creo is storing some visual representation of the cross section and it's not getting updated properly.  The parts are sectioning right but not getting capped right.
It's frustrating to cut a section to check screw engagement, discover you need a longer screw, replace said screw and reactivate the section and at first think that it didn't get resolved.
LinkedIn
Sounds like a reportable bug
Well, I'm using M060 so it's not fixed there.  You nailed the fix.  In fact, all you really have to do is enter the redefine dashboard for the section, no changes required.  Simply hit edit definition then OK.
I agree it's a reportable bug, when I get some free time maybe I'll report it.
LinkedIn
