Is it possible to select a default printer with a .pcf file, so that I don't get the selection window first?
If so, could you maybe upload an example?
Thanks!
Thanks!
I guess that you have pcf file containing following line:
plotter ms_print_mgr
... and you have couple of printers defined in Windows
... and you want to set specific Windows printer for printing from Creo.
Suggestion: Set this specific Windows printer as default printer in Windows.
