In the part you want to mirror, go to File -> Mirror Part. This will
prompt you through creating a part that's a mirror of the one you're
working on.
Doug Schaefer
Senior Project Engineer, Mechanical
www.design-central.com http://www.design-central.com
Tel +1 614 890 0202
Fax +1 614 890 5880
Design Central designet
6464 Presidential Gateway
Columbus, Ohio 43231
USA
Confidentiality Notice
This is a transmission from Design Central Inc, Columbus, Ohio which may
be privileged and confidential, and thus is protected from disclosure.
This message is NOT intended for transmission to, or receipt by, anyone
other than the named addressee (or a person authorized to receive and
deliver it to the named addressee). If the reader of this message is not
the intended recipient, or an employee or agent responsible for
delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution or copying of this
communication is strictly prohibited. If you have received this e-mail
message in error, kindly accept our apology and please delete it from
your system without copying or forwarding it, and notify the sender of
the error by reply e-mail or by calling 614.890.0202 (collect).
Ok, I went home yesterday and worked on the model in question. For the record, I wish I had WF 4 as it seems like it is has some nice new things like this one.
I took this from Dave's suggestion.
Mirror part is unavailable from part mode using WF2.
Create an assembly. Add the part to this assembly that you need to mirror.
Add the datum plane to mirror about.
Use Insert / component / create /
Place a bullet into thepart and mirror options.
Hit OK.
This worked good but after I did this I created more features on the first model and they copied over to the mirrored part. How do I make the two models independent?
