Setting Mass properties for an imported standard assembly
kkr-2
I need to provide mass of a servo motor to a rotating arm, since servo motor model is provided by the vendor and has the spec of weight 200gms. i have assembled into my main assembly. i need to set mass to it for my further analysis. since servo has may parts in it it will be a time consuming - is there a way we assign weight to that assembly and proe will consider for analysis and BOM generation?
1 REPLY 1
As long as you imported it, hopefully it was imported as a "part". Go Edit > Mass Props (from the menu manager). In the dialog box, change the source to "Geometry and Parameters". Click Edit and enter your mass info. Make sure you got the imported part in the correct units.
