Is there an easy way to set materials for imported parts? We import a lot of customer data via STEP or IGES files and need to set either the density or the material, but they all need to be the same. The goal is to set the import files near zero and add a cube with the correct weight and CG location. I had a process in Creo 5, but we just updated to Creo 10 and that process no longer works.
Options:
Options:
Thanks! Option 5 worked perfectly!
