Dear format-wizards,
I am trying to import a company logo into a format. I have received this logo as an *.EPS and I have used software to convert is to a DXF-file. This file I can import to my format but it wont be shaded. I have tried to use "fill" to shade the logo but there are just too many little areas to shade.
Now I have found a workaround: import the dxf as a part, extrude it solid, make a section, fill the cross hatching, place on drawing, make symbol, place symbol on format. Problem with this is that the shading becomes blurry and makes the logo impossible to read/understand
As a workaround for the workaround, I blanked the logo-area on the format and when I make a drawing I add the solid-logomodel to my drawing and I place a shaded view of this model in de logo-area on the format, this creates a perfect company logo on my drawing 🙂
The downside to this solution is that I have to add the logo solid part to every drawing I make for this company and thats not the way I want to work.
Does anybody know how to import a shaded logo into a Format??
Kind regards,
Dennis Varkevisser
I think the easiest way is to download the logo from the company website.
Then use GIMP (a free photoshop clone): http://www.gimp.org/to open it.
Click Image > Mode > Greyscale
Click Colors > Invert
Click Filters > Edge Detect > Difference of Gaussian
Then print to pdf.
You can then use <u>PDF to DXF</u>(http://www.aidecad.com/pdf-to-dxf-converter.html) to convert to DXF.
Once you have inserted into your format, Select all the entities and click Edit > Fill > Hatched.
Attached is an example logo that has been pre-converted for the dxf converter.
In Reply to Dennis Varkevisser:
Dear format-wizards,I am trying to import a company logo into a format. I have received this logo as an *.EPS and I have used software to convert is to a DXF-file. This file I can import to my format but it wont be shaded. I have tried to use "fill" to shade the logo but there are just too many little areas to shade.
Kind regards,
Dennis Varkevisser
______________________________________________
Dennis Varkevisser
Flexible Engineering Support
<u>www.flexibleengineeringsupport.nl
+31 6 50 68 01 79
</u>
