Sheet metal drawing
psimha
Sheet metal drawing
a. We have a sheet metal drawing in which, we have sketched a cosmetic entity against one of its surface.
b. The sketched cosmetic is dimensioned in regards to it's length and width.
c. The same dimensions are called using SHOW-ERASE in drawing mode against that particular drawing view.
d. When the user checks in this drawing into windchill 9.1, the users in other global locations are not able to view these cosmetic sketch dimensions that are given when they check-out this drawing.
e. Please note that, the cosmetic layer is in hidden mode when the user checks in the drawing into windchill
Request you all to help me solve this issue at the earliest. Thanks in advance.
Best regards,
Simha
0 REPLIES 0
