Shortcuts to personalize the views in Creo Parametric
ptc-6785907
Hello people!
I'm a new user of Creo Parametric 2.0 and I need your help to found a way to resolve my problem.
In Solidworks, when you are working with a model (part, assembly, etc.), to use the different views (isometric, back, bottom, etc.) you can choose between 2 options, use something similar to the View Manager of Creo, or also, you can use shortcuts through a combination of CTRL + a number, for example, CTRL + 1 = FRONT VIEW, CTRL + 2 = BACK VIEW, etc.
Is there anything similar in Creo Parametric ??
I know that in Creo exists the View Manager, but it is slow and the shortcuts are faster.
I'd like to thank you in advance for your help.
Good Day!!
4 REPLIES 4
PTC doesn't have shortcuts because it doesn't have pre-defined views. You can create Mapkeys to select views you do define. There are numerous sets of Mapkeys to manage view orientation and definition.
For example http://communities.ptc.com/message/261096#261096
Welcome to the forum, Victor.
If you start your parts with templates, the basic views are pre-defined.
As David said, you can define mapkeys to restore particular saved views as you are use to.
Mapkeys are stored in your config.pro file and can be edited in a text editor.
I do not make many mapkeys but you initiate the process by assigning a keystroke and recording screen picks.
There is a lot more to it to make useful mapkey entries, but that is the jest of it.
tbraxton
(To:dschenken)
Example mapkey to retrieve the top view and comaptible with the mapkeys referenced in the link presented above. This example can be extended to retrieve any named view that exists.
! retrieving top view
mapkey vnt %vnn;~ Arm `visual_dlg0` `Table` 2 `top` `name_column`;\
mapkey(continued) ~ Select `visual_dlg0` `Table` 2 `top` `name_column`;\
mapkey(continued) ~ Arm `visual_dlg0` `Table` 2 `top` `name_column`;\
mapkey(continued) ~ Activate `visual_dlg0` `Table` 2 `top` `name_column`;\
mapkey(continued) ~ Activate `visual_dlg0` `CloseBtn`;
mapkey vnn ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1;
Involute Development, LLC
Consulting Engineers
(thanks Thomas!)
