I'm looking for Creo to use in my company.
I saw in ptc website that they will release Creo 4.0 soon.
I want to know that what is difference between creo 4.0 and 3.0 and pros&cons of creo 4.0 in term of solid and surface modeling and drawing.
Thank in advance
Best regard
3.0, if you don't plan on having paid support, because it has a lot of the bugs ironed out.
if you plan on having the support, then it's your choice basically. 4.0 has the new features, while 3.0 is probably more stable.
I would go with 4.0 + support
What is the stable build for Creo 3.0, with the latest being M110?
M110 will be the stable build for now, I have seen issues on M120 while using M120 during testing.
With a Creo 4 license, you can run Creo 3.
From what I remember, you can't buy a commercial license without buying the 1st year of support, it's part of the deal.
Maybe there are other ways I don't know about.
