Show GTOL in two different drawing sheets
jwilkerson
Hi All,
I have a multiple sheet drawing. On the first sheet, I have the GTOL for the manufacturing side. On the last sheet, I want to show the same GTOL for the inspection side. I cannot get the GTOLs to show up on the last sheet using the Show/Erase function. The views on both sheets are using the same model and REP. The only difference is that the first sheet has a section view. Is there any way to get them to show up on both drawings without creating them twice?
WF 4.0 M100
Jody
1 REPLY 1
Thank you to Bill Samuels, who sent me the following reply:
Create an offset note, list the &g# in it (use info switch dims to get the g number).
It will track with the original feature control frame and always track position to the inspection dim.
It worked great.
Jody
