I am using Creo Parametric Release 10.0 and Datecode10.0.5.0
We have an assembly where certain sub-components might be shown or hidden (suppressed) by ProProgram, based on parameters, for different design cases. Based on that assembly we have created a simplified representation which shows only a subset of the resumed components from the original design (driven by rules). From that simplified representation we need to merge all the visible geometry into one single part and for doing that we have created a shrinkwrap and enable the option to automatically update its geometry based on the original design. While the simplified representation works properly for different design cases, the shrinkwrap does not update its geometry automatically upon regeneration. The only case when it does is when the design takes the "state" in which the shrinkwrap was created, but other cases don't. We have tried searching for some options in the config.pro that might enable such automated update, but couldn't find one that made it work.
Here are the errors that I faced
The shrinkwrap does not update its geometry as expected, although the simplified rep that was used for the creation updates without issues.
What happens if you RMB the shrinkwrap feature after updating the simplified rep and selecting the update shrinkwrap option as shown below?
I am not aware of any config options affecting this but someone else may know of one. You could use a mapkey or script to update the shrinkwrap feature to add some automation.
I did some research and found this option which may be relevant to this. Try setting this to yes and see what happens.
Hi @JacoboOrtiz ,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
