I am using Creo Parametric Release 10.0 and Datecode10.0.5.0
We have an assembly where certain sub-components might be shown or hidden (suppressed) by ProProgram, based on parameters, for different design cases. Based on that assembly we have created a simplified representation which shows only a subset of the resumed components from the original design (driven by rules). From that simplified representation we need to merge all the visible geometry into one single part and for doing that we have created a shrinkwrap and enable the option to automatically update its geometry based on the original design. While the simplified representation works properly for different design cases, the shrinkwrap does not update its geometry automatically upon regeneration. The only case when it does is when the design takes the "state" in which the shrinkwrap was created, but other cases don't. We have tried searching for some options in the config.pro that might enable such automated update, but couldn't find one that made it work.
The shrinkwrap does not update its geometry as expected, although the simplified rep that was used for the creation updates without issues.
What happens if you RMB the shrinkwrap feature after updating the simplified rep and selecting the update shrinkwrap option as shown below?
