Simp Rep name in drawing
Gucio
Hi all,
is it possible to get/show simp rep in note/table?
I would like to have sth similar to assembly process - every sheets show different stage of assembling. Stages are created as simp rep. Each sheet as a note or in table should display name/description of particular stage.
Thanks in advance for the consideration
Best Regards,
Krzysztof
Krzysztof
mender
(To:Gucio)
An interesting idea.  An ordinary callout can't talk to 'a specific simp rep of an assembly', though it could to a simp rep of a part.
However, it would be possible to have a callout 'the name/type/rep/step [four separate callouts] of the top model in a specified view'.
To request this, please make a Product Idea.  It would be fairly simple to implement, but might want to show that it will benefit a number of users.
I would strongly advise you not to go down this path and instead use tools that are intended to document assembly instructions.  Pro Process and or Creo Illustrate
