Hello Community, how are you?
Can anyone tell me how to create a simp rep from holes I made in an assembly? I need to hide the holes I made in the assembly and I tried simp rep, but it only lets me exclude parts and not characteristics. Has anyone done something similar?
Thanks!!!
I understand... and thank you very much for the information!!! I thought there was something about Simp Rep inside the set that did it by feature!!! But I'll apply your suggestion and make the texts.
Thank you very much and have a good job,
One way is that you can go into the drilled parts, there create a simp rep (let's call it "BEFORE_DRILLING") which excludes the assembly cut features. Then go back to the assembly and define a simp rep where you substitute the drilled parts for the user-defined "BEFORE_DRILLING" versions.
Unfortunately you can't control an assembly feature with a simplified rep.
There is a product enhancement request to add this feature, if you have a chance, take a minute and go add a kudo to that one.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Let-me-rep-out-assembly-features/idi-p/846902
