Simplified Rep of a Part in a Drawing View of an Assembly
ArnoldCollett
In the view manager of the assembly, click "edit", "redefine" for the "No_thru_cuts" rep; then click on the "substitute" tab, pick "plate-1", click the "No_circle" rep and then click "Accept", then pick "Plate-2", click the "No_square" rep, click "Accept" and then click the green checkmark. Then it will save the way that you want.
One extra hint is to use the same rep for all parts, (ex. "No_cuts" rep), then you can select all of the parts at the same time and select the one rep to substitute.
Hope this helps,
Arnold
1 REPLY 1
Using "Substitute" is indeed the answer. Thanks for the tip. I knew there had to be a way to make the Simplified Rep of the Assy "remember" to use the Simplified Rep of the Part.
Merry Christmas to all..., and to all a Good Night!
