Simplified reps and BOM balloons
HeavyGen
Working on a master assy drw with a set region BOM table. I have a couple simplified reps within the master assy. The goal is to use the simplified reps to create views for showing different areas of the whole assy and use the balloons from the original set region BOM. Is this possible? From what I can tell, simplified reps are treated as seperate assys that require their own set region BOM to display driven balloons. Is there any way around this? I imagine this has been asked a few thousand times. Working in WF 4.0.
1 REPLY 1
Kevin
(To:HeavyGen)
The way around this is to create tables for each rep on the drawing and fix the indices for the rep tables so they match the master rep table. You can then add ballons to the reps and hide the tables for them when you are finished.
