Sketcher Symmetry
ptc-3035498
Sketcher Symmetry
We have just had wildfire 4 installed. With wildfire 2, in sketcher, I was able to sketch my shape roughly either side of a datum plane and then use a centerline to 'snap' the shape to be symmetrical. This no longer seems to work with the new install. Does anyone know how to get it back ? I have intent manager switched on, and I realise I can make the shape symmetrical using constraints, but the old way was so much quicker. Any ideas ?
6 REPLIES 6
I believe it still works. What you may need to do is sketch the centerline (horizontal, vertical or both) first, right on the sketch references (presumably datum planes). Then if you sketch, for example, a rectangle, it should snap to symmetrical on those centerlines.
Chris Benner
Autodesk ® Expert Elite
Thanks Chris, that works to a certain degree but if I put 2 circles in the rectangle either side of the datum I still can't get these symetrical using cetrelines.
you could use mirror in sketcher Reinhard
good suggestion, but the question remains: How can I get the symmetry using a centerline ?
With 2 separete entities (ie 2 circles)... you can't. Not without using mirror, or adding a constraint later. No other way that I'm aware of. I wasn't aware that you ever could. That might be a handy thing.
Chris Benner
KrisR
(To:CBenner)
I use symmetry all the time.......on the flyout if you choose symmetry constraint, you click the centerline (you have to use the centerline command in the lines flyout), then the two objects you want to make symmetric, such as circle centers, and they will snap symmetric.
Here is a video for you....
http://communities.ptc.com/videos/2880
