My thanks to all that sent me ideas to try, especially to Joanna who came up with the resolution. She pointed me to files that Intralink creates when you define a Pro/E command. They are located at drive:\~\.proi\.data\user.data\start". Inside this directory, you will find files with the name of your Pro/E command. The solution was to edit this file, so that the full pathname was in quotes, due the spaces.
.cm
"C:\PTC\proeWildfire 3.0\bin\proe3.bat"
Rob Devaux
Sr. Tool Designer
ABA-PGT, Inc.
10 Gear Drive
Manchester, CT. 06042-0270
United States of America
(860)649-4591 ext. 120
fax (860)643-7619
rdevaux@abapgt.com
www.abapgt.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
That is interesting because I have nothing in my ~\start directory. I defined the startup command during the setup of Pro/INTRALINK and my the batch file for Pro/INTRALINK contains the start command for Pro/ENGINEER (proe.exe). This is the best way to go in my opinion because I am not specifying a single Pro/ENGINEER command. Using proe.exe will pop-up a dialog box for any command (.psf file) that I have defined through the setup process of Pro/ENGINEER. It's up to you though Rob.
