In one of our assembly drawings, some models edges are not displayed (that should definately be displayed).
We saw this many years ago, and thought it was fixed, but it seems to have returned.
It happens when some parts of the assembly interfere, but not by a noticable amount.
If we blank the suspect interfering part, the all edges of the rest of the assembly displays correctly.
The missing edges can happen anywhere, and not neccesairily near the region of interfereance.
Sometimes, it is the outermost edges of a part, which really looks wierd.
Has anyone else see this behavior?
CE Pro 5 M150 with Windchill Intralink 9.1 M060
Gerry Champoux
Williams International
Walled Lake, MI
Thanks to all that replied.
Along with your responses and some more searching at PTC's knowledgebase, I have confirmed that this is indeed a situation where there are interfering assembly parts (such as a press fit). PTC says that this is still a known limitation of Pro/E, and they do not intend to address it because it would introduce severe performance penalties.
The only adequate work-around is that we must ensure that parts do not interefere.
Gerry Champoux
Walled Lke, MI
In Reply to Gerry Champoux:
Sometimes, it is the outermost edges of a part, which really looks wierd.Has anyone else see this behavior?
I don't intent to bring up a ghost thread, but what about an assembly where a screw is going into a threaded hole. For example, a #8 screw, with a nominal thread dia of .164 goes into a hole feature using UNC table, threaded for a #8 is .136. There is an interference in the assembly. In the ISO view, the hole disappears and the lines for the shaft of the screw. Any tips, tricks or solutions we can use?
Thanks!
I have been thinking about the interferences a lot lately. How about changing one of the interfering parts into a Flexible Part within the assembly?
You could then reduce the offending component to a size that would eliminate the interference in that particular assembly. This would eliminate the hidden line problem in the drawing.
Just pondering the idea.
Interesting, but it won't work if you set your models to READ ONLY before releasing it.
DRAWING VIEW- VIEW DISPLAY- DISPLAY STYLE (SET TO HIDDEN)-CLOSE
LAYOUT- EDGE DISPLAY- HIDDEN LINE(IF HIDDEN)- SELECT THE EDGES WHICH ARE NOT VISIBLE- OK
GO BACK TO..
DRAWING VIEW- VIEW DISPLAY- DISPLAY STYLE (SET TO NO HIDDEN)-CLOSE
YOU WILL FIND THE HIDDEN EDGES THAT YOU HAVE SELECTED.
THANKS
