Some parts not visible in assembly in BOM table
SJ_9672882
2-Explorer
Hi, i am having problem with displaying my part in BOM table. I can only see parts or assemblies, that are downloaded from FESTO website. Can anybody please help me? thank you :))
Can you please check BOM table simplified representation.
Path is -->  select repeat region --> select model /rep --> select your BOM table --> select your assembly part number --> select master rep
then check it.
Definitely, it will solve your question.
From that, if you want to show your simplified representation/required BOM in the drawing table. approach in that way.
Balachandran M
chandrumx6@gmail.com
3 REPLIES 3
StephenW
(To:SJ_9672882)
What parameters or values is your bom table using? If the table is using the parameters the parts/assy's don't have, they won't show up.
If your table has filters or relations, it could cause parts/assembly's to not show.
If you have sub-assy's and you want the parts in the sub-assy to show, you have to set the item or table to recursive.
There are potentially a lot of reasons.
in Drawing mode save repeat region table as .tbl file and upload it. This enables us to see repeat region definition.
If it is possible, you can zip drawing + assembly + part files into zip file and upload this zip file.
Martin Hanák
then check it.
Balachandran M
