Standard part creation with Parameter prompts
btheobald
7-Bedrock
All,
I need to generate a Standard part that prompts the User to submit details for Parameters "PART_NO" & "DESCRIPTION" at the time the 'new part' is in created. Any suggestions?
Thanks in advance.
Bob
unfortunatelly requested functionality is not implemented in Creo. Building custom application can solve your problem.
MH
Martin Hanák
If you designate the parameters, they show up in the new file options dialog.
They can, of course, ignore them and leave them blank, but it at least puts them in from of their eyes.
You'll also want to set the config option"force_new_file_options_dialog yes" to uncheck the "Use Default Template" box in the new file dialog.  Putting that in your config.sup disables that check box so the user must go to the New File Options dialog.
LinkedIn
