Status query
jnanesh.sajjan
Status query
I am bit struck in a confusion. I have an assembly in which one part is
having some symbol in model tree. I checked the assembly constraints and
it is found to have fully constrained. I am not able to get the reason
of appearing of this symbol.
Thanks and regards,
Jnanesha KS
T 91-80-4119 0900 Ext: 233
F 91-80-41190901
M 994 500 4179
Quality Engineering and Software Technologies
No 55 l QuEST Towers l Mahadevpura l Whitefield Main Road
Bangalore l 560048 l www.quest-global.com
3 REPLIES 3
Hello again,
Just now I checked and came to know that the particular part is
constructed using external references. Is this anything to do with this
status symbol?
Jnanesha KS
I guess that one of the parent references for this component is not fully
constrained. I think the icon indicates "Child of Packaged".
/Bjarne
Jnanesha K S <->
17-09-2010 07:22
Please respond to
Jnanesha K S <->
To
cc
Subject
[proecad] - Status query
it is found to have fully constrained. I am not able to get the reason of
Thanks and regards,
Jnanesha KS
F 91-80-41190901
M 994 500 4179
Jnanesha,
If you Right-Click the item in your Model Tree, then go to Info >> Reference Viewer, you should see where you are probably missing references.
Brian
