[Summary] ball mechanism with constraints??
nkaminakis
Good morning Vassilis,
I did it somehow, with out auxiliary parts, using simple assembly
constraints / NO mechanism constraints.
I have created a revolved surface in the ground part, and then placed 2
assembly contraints:
1) align point to point
2) point to the revolved surface
I didn't placed any other constraint. This way i got the ball constraint as
I wanted.
BUT!!!!!!!!!!
I tried the following:
Used a general mechanism constraint: I placed the part using 1) align point
to point and 2) trying to make an "point on to surface" constraint. Pro/E
didn't allow me do that. Pro/E allows only planar surfaces to be used. Not
revolved surfaces. I don't know if this is a bug or a feature. Is there any
other way?
I use Pro/E WF5 M70 (Creo Elements/Pro 5 M70) 64bit , Windows XP64
you can check the attached zip file, containing the assembly.
On Mon, Feb 13, 2012 at 09:52, Anagnostopoulos, Vassilis <
-> wrote:
> Hi Nikos,
> you will need an extra auxiliary part and the following procedure to
> achieve this
> 1. Create an axis that passes through your first point on your base
> assembly.
> 2. Create an auxiliary part with two perpendicular axes.
> 3. Assemble the aux part with a pin joint (use here the first of the two
> axes) on your assembly.
> 4. On your part now with the given point, create an axis that passes
> through that point.
> 5. Assemble your part to the auxiliary part (on the second axis) using
> another pin joint. Define on this pin joint the required limits and you
> are done.
> hth
> Vassilis Anagnostopoulos
> SPIDER SA
> Industrial Area - Rodotopi
> 45500 - Ioannina
> Greece
-nk/.
1 REPLY 1
