Summary: emails not getting added to call details???
dgschaefer
"If you ever fail to use reply all, and just hit reply, the chain is
broken."
That's a recipe for failure.  Any time a process requires a specific
action of multiple possibilities for success, especially when that
action is not what the user is likely to, it's a flawed system.  It
should be designed to work with the most common action (in this case
'reply' rather than 'reply all') and to be fault tolerant (accept a
'reply all' as well).  I suspect many calls aren't getting the emails
logged.
I mention this in the simple hope that someone in PTC support might be
eavesdropping.
Doug Schaefer
LinkedIn
1 REPLY 1
davehaigh
(To:dgschaefer)
My understanding is that this was done for security reasons.
Not exactly sure how it works, but I'm guessing there is some BCC addressee that enables this to work.
I agree, it's sub-optimal.
David Haigh
