Supercar body with Creo Freestyle feature
VladimirPalffy
My custom design of supercar body.  Created/modeled with Freestyle feature in Creo Parametric 2.0
Note: you can download Creo Parametric model https://grabcad.com/library/k-4k-1
Vladimir
Best Regards,
Vladimir Palffy
4 REPLIES 4
Well done Vladimir!
I have played around with Freestyle for a bit as well but never taken to that level.
Did you only use pictorial reference (trace sketch) or also some sort of parametric datum reference?
Hi Constantin, thanks for your comment.
I have created the main body shape based on imported geometry (I have used the Merge/Inheritance heature) + Freestyle feature.
A the end of this model I have use a few projected curves and Boundary blend feature - try to check/download my model here: https://grabcad.com/library/k-4k-1
Good luck,
Vladimir
Do not forget check my project library and "LIKE"my models , Thanks
Best Regards,
Vladimir Palffy
Fabulous!  Great work as always.
Thanks Timothy
Best Regards,
Vladimir Palffy
