This widget could not be displayed.
Supports in spec driven piping
jsarkar
Does anybody know how to configure supports in spec driven piping for multiple pipe lines?
Do you mean a single fitting supporting multiple pipes at once or a fitting that is used by different specifications?
I have no idea for the former, while the latter is quite simple: just enter the support in the asfiles for each pipe spec. The same support can be used by multiple specs.
Your previous one, a single support containing letsay u bolts for multiple pipe lines.
gkoch
(To:jsarkar)
So in real life you use supports that can hold multiple pipelines.
And you want to model this in Spec Driven Piping, using the same instance of a support fitting for several pipe segments (from different pipelines), right?
Spec Driven Piping is not my specialty, but I can imagine that this is difficult to handle from the logic in the program...
jsarkar
(To:gkoch)
Thanks for your answer. I have now try to find alternative solution, beacuse we have branch of pipes and we need to show common support for different pipe lines.
