We are on WF4.
We are planning to start adding a mass analysis feature in the Footer of our model. We will also be adding a relation to the modelin the Post Regeneration area MASS_PER_PIECE=MASS:FID_MASS and a notein the title block on our formats: WEIGHT: &MASS_PER_PIECE lb
During my testing if i change the value of a dimension then the value on the drawing automatically updates just by switching from the model to the drawing. Great. Works like a charm. But ifI suppress a feature in the model the value on the drawing does not update. It will only update after I regenerate the model.
We do not have the the mass_property_calculate set in our system config and do not want to set it to automatic.
Does anyone know if there is a way to get thevalueto update automaticallyin our title block without us having to hit the regenerate?
Steve G
The way to get it to automatically update in your title blockIS through the use of mass_property_calculate set to 'automatic'.
You could try Edit > Setup > Mass Props > Generate Report. See if that updates your MASS_PER_PIECE parameter. While it's not automatic, like the config option, you could make a mapkey to speed it up.
In Reply to Steve Galayda:
We are on WF4.
Steve G
