"David Butz" wrote:
Chris, Not sure of what you are doing exactly, but you may want to explore a Variable Section Sweep using a Graph Feature where you could control height and slope directly and the so-called trajpar parameter. If they are what you need and you are not familiar with their use, we could give you more detail. David
"Mark Kelley" wrote:
I've attached my interpretation of what you are attempting to accomplish. Style Features let you manipulate geometry in a manner that you describe -in real-time!
"Richard Giguere" wrote:
actually my method is full of holes sketched datum points along a curve will not move it if you very there x or y dim. The point will move up and down off the curve, won't affect the slope at all oh well.......back to the drawing board.
"C M" wrote:
Did you try using a graph to modify a VSS?
