Surface swept blend
mbonka
Surface swept blend
l have a problem with swept blend feature. Can´t put right "control points" together and results swept blend is rotated.
What i have tryed:
- rotate sketches
- redefine secondary sketching plane (know sometimes it makes similar rotating with boundary blend feater)
3 REPLIES 3
TomD.inPDX
(To:mbonka)
I have had luck with adding control points in the feature's UI. It seems easier than reorienting the sketches.
If you sketches do have the right locations but it chooses the wrong ones, try dragging the white dot to a new vertex location along the sketch curves.
l pressed bad buton... its only half of topic, wait a sec please.
mbonka
(To:mbonka)
Thanks you for REALLY QUICK reply.
l created new "same" topic.
Admin could you delete this discussion please.
