Swept blend feater is rotated
- July 25, 2014
- 1 reply
- 1601 views
l have a problem with swept blend feature. Can´t put right "control points" together and results swept blend is rotated.
What i have tryed:
- hangling white points around all vertexes
- rotate sketches
- redefine secondary sketching plane (know sometimes it makes similar rotating with boundary blend feater)
- define swept blend X-direction (just tryed my luck --- not familiar with this)
Part file should be attached.
First question:
Could you explain me what is wrong with second swept blend feater?
Second question:
Do you have any idea how to do middle part better way? Just in 1 feater without merge?
