Table Pattern not working in Creo 2
vkumar-10-11-123
I am working in Creo 2.
I want to edit a pattern table but I could not edit it, it says that "Cannot open file". What could be the reason? Even I am facing difficulty to create a new pattern table feature.
Please advise.
8 REPLIES 8
when I click Edit button, Pro/TABLE editor opens. Rename your config.pro files temporarily and test Creo behavior.
MH
Martin Hanák
For me, When I click edit button, not opening any window. Instead of that it says that "Cannot open file".
bump.
Me too.
I get this when the working directory for Creo cannot be written to. You need permission to create the temp file the table editor works with.
Hi All,
I have changed the working directory by selecting the options-> environment-> working directory-> "c:\windows" to "c:\apps\creo\creo 3.0\M050\".
it is working fine
how do I determine what my working directory should be??? the location should depend on where creo was loaded?  Is there a specific folder I should be pointing to?
working directory is the directory in which you want to save your data. For example:
C:\mycreodata
-OR-
C:\Users\Public\Documents
-OR-
any directory you create
You need full access rights to the directory to be able to create/delete files.
MH
Martin Hanák
found below link.  working directory seems to be right so tried changing the browser type (from Mozilla to Ie).  logged off/in couldn't get back in.  changed back to Mozilla, logged off/in. pattern tables are working, which I guess is all that really matters...
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS206558
thanks to everyone for your help.
