Brad,
Yes, you should be able to use the paginate under the table menu.
First select an entity in your table then pick Table>Paginate. You then pick a point on your current table to set the extent of the the first portion. Then pick Add Segment and pick a point on the screen to set the rest of the table. This can be repeated as needed.
Brent
Brad,
Brent
