Tables
bmozley
Tables
ProE users,
I have a family table with 100+ instances for a part.
When I create a drawing , I have one long table that does not fit onto
my drawing
format. Is there a way to split the table to have multiple columns for
dash numbers (instances)?
Brad
WF3
Brad,
Yes, you should be able to use the paginate under the table menu.
First select an entity in your table then pick Table>Paginate. You then pick a point on your current table to set the extent of the the first portion. Then pick Add Segment and pick a point on the screen to set the rest of the table. This can be repeated as needed.
Brent
Brad,
Brent
