Template does wonky stuff
cheezbert
11-Garnet
Hello again PTC-Community!
I am trying to make a template out of a sick, but it seems Creo doesn't want me to.
It just goes from this (which looks fine to me)
To this...
Which does not seem to be right.
Anybody know a solution to this? 
cheezbert
11-Garnet
(To:remy)
thanks, guess i'll give our distributor a call about it, since we have a premium subscription with them!
EDIT:
guess i was actually just stupid..
made a silnge part as template and boom it worked..
6 REPLIES 6
remy
(To:cheezbert)
Hi do you mean that the pattern result is different from the previous of the pattern feature?
cheezbert
11-Garnet
(To:remy)
Yeah, exactly..
remy
(To:cheezbert)
thank you for your confirmation.
Have you try that same pattern on a model from scratch or does it happen solely on that model? (need to sort out if this is a general behavior or specific to the model / workstation))
cheezbert
11-Garnet
(To:remy)
Unfortunately i can't recreate the issue now.
but also, when i want to do the template by measurement i can not go in the direction where the 6 would be.
remy
(To:cheezbert)
this needs a closer hence, i recommend you file a case at support: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
cheezbert
11-Garnet
(To:remy)
EDIT:
