The option add note unchecked by default
tvasina
How to have the option add note unchecked by default when creating a standard hole feature in Creo Parametric?
I guess that such config.pro option does not exist.
MH
Martin Hanák
I also did not find a command line in config.pro. I will push this question to Idea section.
TV
Hi Tomas,
It isn't possible to uncheck this option by default.  I think it will be a good idea to push it to the Idea section, so PM can take a look.
Amit
