The simplified representation of the engineering drawing does not work
bduncan
Hello everyone, I created a component in 3D, and then created any simplified representation, such as NO-A, N0-B, and then saved it. Then I created a new engineering drawing and selected a simplified representation such as NO-B, but the repeated area still shows component B. How can I solve this problem? Thank you
Translated the topic from Simplified Chinese to English using Google translate
Subject - 工程图简化表示不起作用
Body - 大家好,我在3D建立一个组件,然后建立任意一个简化表示,如NO-A,N0-B,然后保存,接着新建工程图,选择一个简化表示如NO-B,但是重复区域还是会显示元件B,请问这个问题如何解决,谢谢
-By Community Moderation Team
7 REPLIES 7
please replay uploaded video. HIH.
Martin Hanák
谢谢你的视频,但是为什么我的操作还是不能达到你的效果?谢谢
附件是我的模型,能帮忙分析是什么原因造成的吗
kdirth
(To:bduncan)
In your simplified rep, you have B.ASM set as Exclude which would normally exclude the sub components in the assembly.  However, you have also explicitly included the parts C and D.  The recursive BOM is adding B.ASM to maintain the BOM structure.  If you don't want B to not show try filtering by item to hide B.
kdirth
(To:bduncan)
The repeat region BOM will always show the model/representation of what was active at the time the BOM was made until you change the Model thru the repeat region menu.
Table tab > Repeat Region > Model/Rep > Select repeat region (table) > Select model > Select representation > Confirm > Done
bduncan
(To:kdirth)
谢谢你的解答,但是我的操作还是不能达到预期的效果
uploaded video show how to remove B item from repeat region.
Note: You do not have to define simplified representation in A.asm
Martin Hanák
