Hello everyone, I created a component in 3D, and then created any simplified representation, such as NO-A, N0-B, and then saved it. Then I created a new engineering drawing and selected a simplified representation such as NO-B, but the repeated area still shows component B. How can I solve this problem? Thank you
Translated the topic from Simplified Chinese to English using Google translate
Subject - 工程图简化表示不起作用
Body - 大家好,我在3D建立一个组件,然后建立任意一个简化表示,如NO-A,N0-B,然后保存,接着新建工程图,选择一个简化表示如NO-B,但是重复区域还是会显示元件B,请问这个问题如何解决,谢谢
-By Community Moderation Team
please replay uploaded video. HIH.
In your simplified rep, you have B.ASM set as Exclude which would normally exclude the sub components in the assembly. However, you have also explicitly included the parts C and D. The recursive BOM is adding B.ASM to maintain the BOM structure. If you don't want B to not show try filtering by item to hide B.
The repeat region BOM will always show the model/representation of what was active at the time the BOM was made until you change the Model thru the repeat region menu.
Table tab > Repeat Region > Model/Rep > Select repeat region (table) > Select model > Select representation > Confirm > Done
谢谢你的解答,但是我的操作还是不能达到预期的效果
uploaded video show how to remove B item from repeat region.
Note: You do not have to define simplified representation in A.asm
