I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
We are getting the transaction log for the wtuser database filled up error.
This morning I tried to shrink the log file, and it helped for 5 minutes. Then I truncated the logs and it helped for a short period of time again. But it gets filled up pretty quickly and users can't use the app anymore.
A user's report:
I open PTC Creo, then click "Workspace" on the left. Then type in the search bar next to the "Quick Links" drop down menu. I search for "model*" to try and access our assembly. It then says:
An unexpected error has occurred while performing search. Please contact system administrator.
And that's when I click OK I get Windchill error.
Exception: wt.util.WTRuntimeException: A persistence error occurred. Nested exception is: A persistence error occurred
Here are the errors that I faced
MSSQLServer Event 9002: The transaction log for database 'wtuser11' is full due to 'LOG_BACKUP'.
See suggested solutions for this error here:
The provided links does not solve the issue.
We could not find what caused the transaction log to fill up to its capacity so fast. Like in 5 or 10 minutes, when it would never do it before.
We just switched to Simple backup mode for now. Will come back to this problem later.
