Hi, I'm Fabio and I'm using Creo 7. I have a question about line thickness in Sketch mode. For example when I create a new part and select the sketch mode I notice that when I hover the mouse over the center line, the line changes color to green and the thickness increases a lot or when I draw a circle, for example, and I confirm the size, the circular line turns green and the thickness increases considerably. Is it possible to change the thickness of this green line? I have already changed the SKETCHER_LINE_WIDTH parameter in config.pro but it's not that. I noticed that in Creo 6 this green line is thin and not thick like in Creo 7.
Thanks for any help.
bye
Fabio
bye
Fabio
please upload some picture or make a video showing the problem.
Hi Martin,
Attached are two images showing the difference from creo 6 and creo 7 sketch and that's is want I mean.
I would like change the thickness line in Creo 7 as in Creo 6.
Fabio
Hi Martin,
Fabio
I guess that line with of selected item is hardcoded. To be sure please ask PTC Support.
https://www.ptc.com/en/support/article/CS320370 contains following text in Visualizing Design Intent in Sketcher Is Improved section.
I suspec it is a harcoded.
I tryed to change the sketcher_line_width from 1.5 to 1, for example, but doesn't change.
I will ask for a confirmation from ptc support as you suggest, but I think it is not possible to change without change a program line code.
I prefer the Highlighting thickness in Creo 6, sincerly.
thank' s for your help
Fabio
@Fabio_Ugoletti Hello Fabio,
I just switched from Creo 2.0 to Creo 8.0 and I also found the graphical aspect of the sketch environment not good.
From the config I was able to report it as Creo 2.0, see:
sketcher_line_width 1
sketch_thick_dim_line_highlight yes
sketcher_pre_creo4_constraints yes
But it is not possible to reduce the thickness of the highlights. See my request:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Change-the-thickness-of-the-highlighted-sketch-lines/m-p/752010#M121076.
Not being able to do it I made a request as a future idea, see this link, if you like it I ask you to rate it!
https://community.ptc.com/t5/Creo-Parametric-Ideas/Add-a-config-option-to-come-back-to-the-highlighting-with-thin/idi-p/751985
