Hi everybody.
I cannot remove the thread lines where you can see the part have an extrude. The lines from the hole are gone if i remove the thread, but the lines from the thread appear again when turned on.
Hope someone can help
if you change feature order then you will get what you need.
Hole 1 ... created before Extrude 2 ... displayed right
Hole 2 ... created after Extrude 2 ... displayed left
you can put the thread/hole into a layer and hide this layer in specific drawing view.
Is it possible to keep the thread lines on the item, and only delete the lines outside the item, using layers?
NO, it is not possible. I guess that you can "solve" your problem by creation of specific surface, only.
Hello @JM_8672405,
It looks like you have some responses from a community expert. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
It worked 😃 Thank you very much for helping me 🙏
