We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
Thru Hole with thread
DeanLong
Happy back-at-it gang,
Are we still hamstrung by our bestest, fastest, most bomb-diggetyest hole feature not allowing a thru hole with a thu all thread?
17 REPLIES 17
Dean,
I just created a thru all thread using the hole feature (Creo 2.0, M100)
[cid:image001.jpg@01CF7991.0E7CC330]
[cid:image002.jpg@01CF7991.0E7CC330]
Mike Brattoli
Moen Incorporated
DeanLong
(To:DeanLong)
Could this be a license thing....or a dreaded config option?
What's interesting is once I put a countersink or counterbore on it the thread no longer goes through the entire part - never dull.
Mike Brattoli
Moen Incorporated
DeanLong
(To:DeanLong)
NOoooooooooooooooo! 🐵
Dean Long
NeuTech Associates, Inc.
941-388-8683 office
248-563-5112 cell
www.neutechnet.com
Try changing from "up to surface" to "thru all".
I think it's another "opportunity". My option is grayed out as well but I can select Thru All from the pulldown depth icons and it works fine that way, as long as there is no counterbore/countersink.
Another interesting factoid - if I try using the depth option "Up to a selected surface/point/etc..." instead of Thru All it worked fine for me though it looked like it didn't for you - crazier by the minute! And to top it all off, with the "Up to a selected surface...." Option used I could add a counterbore / countersink and it worked perfectly!!!!!! AAAAAAARRRRRGGGGGGHHHHH
I'm running the equivalent of the old Flex3C configuration - I also tried it using a default Foundation license - got the same results.
[cid:image004.jpg@01CF7993.B65D1260]
[cid:image003.png@01CF7993.2627CE10]
[cid:image005.png@01CF7993.B65D1260]
[cid:image006.png@01CF7993.B65D1260]
[cid:image007.png@01CF7993.B65D1260]
Mike Brattoli
Moen Incorporated
DeanLong
(To:DeanLong)
FYI.....I am in an assembly mode and it seems it still will not work after all these years.In part mode it's allowed and works fine. I don't do a lot of holes so Iwas surprised to find it's still not allowed to go thru allin .asm's. I don't understand why we still do not have this ability since the assembly model features are not affecting the parts in any way. The ATB "should" have a great grasp on this and should allow it. <sigh>
DeanLong
(To:DeanLong)
I retract.......Mr. Brattoli has the magic. Use the drag handle to tag the depth to the vertex of the I.D. The thead follows. All other bets are off.
DeanLong
(To:DeanLong)
I double retract......the thread is still not "thru all" even dragging the handle. Back to square one.
Just wondering...
What exactly does one do with a threaded-c'bored hole. Do you just put a screw in it to plug the hole?
I guess I can image some possible uses but none of them are really a 'standard' hole. More like a hole with some additional features I'll just like to be rolled into one feature.
Believe me, I'm not saying Creo is right about this but I think they were going for 'standard holes'. We of course, always want more...
T
I agree about counterbore - seen it on occasion but rarely. Figured I'd try out the options 🙂
Consistency would be greatly appreciated though from PTC
Mike Brattoli
Moen Incorporated
Ring dowel?
Jonathan
JWayman
(To:DeanLong)
"It's intended functionality, but since, in the real world, people need to do this, here is a way to bodge it so it looks approximately like what you want."
Or they could just change the spec so that Intended Functionality resembles real-life requirements...
They don't even make an attempt to justify why it is Intended.
"Earth calling Needham, Come in, Needham."
John
DeanLong
(To:DeanLong)
Here, here, Mr. Wayman!
Dean Long
941-388-8683 office
248-563-5112 cell
www.neutechnet.com
DeanLong
(To:DeanLong)
And for those that may need it, here is the location ofcosmetic in assembly mode to add the cosmetic thread as stated in PTC's work around.
There is a "match" that will automatically "know" what thread size to add if you choose the hole feature as the reference.
Happy Threading my friends.
cprice
(To:DeanLong)
You may want to try to place a full thread in assembly mode - if my memory is correct, there is a problem doing so.
Charlie Price
Strategic Technical Services LLC
Phone 330.887.9295 Desk/Mobile/FAX
Main 888.479.1566x127
charlie.price@stechservices.com
