Is there any facility to record steps LIVE that are taking place on the Creo 2.0 screen when the user is in the process of creating a model, an assembly or a drawing? Please revert if you find any solution. Thanks in advance.
Best regards,
Simha
Your trail file will capture every move you make within each session.
Hi Ron,
Thanks for your reply. Can you please let me know the steps to play the trail file?
Thanks Ron.
Prasanna,
Additionally, if you set the config option set_trail_single_step yes, you, or another user, will be able to step through your trail file to see each step/action.
Amit
Thanks Amit.
Hi Prasanna,
If you wouldn't mind, please indicate which of the replies is the Correct Answer, as per which one helped answer your question.
Amit
