Creo Parametric 3.0 M040 *.UI file
ashaikh
Please can any one  send me the default original *.UI file for Creo Parametric 3.0 M040 . which contains the original tools on creo default layout. It will be better if schools tab is added. Also mention steps to set it as default.
Hi Azim,
Is this regarding the Student Edition of Creo Parametric?
Amit
Azim,
As mentioned in an earlier thread Creo Layout Changed (Tools/Tabs) we can not help unless you provide more information.
The creo_parametric_admin_customization.ui and/or creo_parametric_customization.ui files is what you are after.
Not knowing your arrangement, you may want to try the following
  • check your recycle bin for a discarded copy
  • check to see if there is a server version.
  • copy an associates creo_parametric_customization.ui file (that has what you want) and place it in your start up directory
  • rename the creo_parametric_customization.ui file in your start up directory to creo_parametric_customization.old and restart creo to see if it returns
Ron
