Hi
i have trail file .
It work perfect if i have only one component whit same name in assembly . if i have two or more dosnt work.How to change that this will be work. .
Thanks TP.
I don't think anyone understand what you are asking. What is your goal? What are you trying to accomplish?
record trail when two or more component with same name are present in assembly. Replay attached video.
Hi for better understanding.
Please see video.
In attachment you also have trail file.
Goal is if i have 20 parts to unlock i use this for unlock. If i don unlock i can not edit this parameters. So in excel table i mark which i would like to unlock than i crate trail file and unlock,
I hope this help you for better understanding.
TP.
I am sorry I do not use EMX. Therefore I cannot help you.
Hi
But I think the problem is how to activate a part when there is more than one part. Maybe choosing a different method would help.
Any tips. maybe difrent filter
TP
You're trying to unlock parts. Are you using Windchill? Are these Locked in the workspace?
I know there's a settings that will Lock all files in the Workspace, and that you can change that setting. There may be similar settings for Creo without Windchill to set files as read-only. I'd recommend reviewing your config settings and making sure you don't have something locking the files for you.
