Transform world units to drawing units - ProDwgtableColumnSizeGet
LarsZiegler
8-Gravel
I'm reading the size of a table column with ProDwgtableColumnSizeGet().
How can I get or convert the size to drawing units.
I tried it with ProDrawingSheetTrfGet.. and ProPntTrfEval but nothing works...
Some ideas?
Thanks for your help!
Greetings Lars
I Lars,
I’ve a similar problem setting the position of a note in a drawing.
I followed these steps:
1) Setting the attach point to ‘translate’
2) find the transformation matrix of the sheet ( from screen a drawing coordinates ) using ProDrawingSheetTrfGet (ProMatrix)
3) calculate the inverse matrix
4) translate the vector from drawing to screen coordinate using ProVectorTrfEval
5) add eventual shift to the new vector
ProVector pos;
ProMatrix matrix, inverse_matrix;
// initialize the position
pos[0]=X;
pos[1]=Y;
pos[2]=0.0;
// get the matrix from screen to drawing coordinates
ProDrawingSheetTrfGet ( drawing, i, wNomeFormato, matrix );
// get inverse matrix ( from drawing to screen coordinates )
ProUtilMatrixInvert( matrix, inverse_matrix );
// drawing to schermo
ProVectorTrfEval ( pos, inverse_matrix, pos );
// add shift
pos[0]+= inverse_matrix [3][0];
pos[1]+= inverse_matrix [3][1];
You can find ProUtilMatrixInvert in <proe_root>\protoolkit\protk_appls\pt_examples\pt_utils\UtilMatrix.c
I hope this help.
Michele Giudici
Descrizione: Logo CDT piccolo
CAD.I.TECH - CAD Integration TECHnology S.r.l
+ via Montevideo 7, 16129 Genova
( 010 362 62 66 - Ê 010 362 62 67
thanks for your answer.
The problem was the number of the column.
In some Toolkit functions the index starts at 1 but in
ProDwgtableColumnSizeGet the index starts at 0!!!
Here my code:
ProPoint3dpt;
ProMatrixMatrix;
intSheet;
ProNameSheetSize;
pt[0] = 0.0;
pt[1] = 0.0;
pt[2] = 0.0;
err = ProDrawingCurrentSheetGet(m_Drw, &Sheet);
err = ProDrawingSheetTrfGet(m_Drw, Sheet, SheetSize, Matrix);
if (m_ATitleCells.size() > 0)
err = ProDwgtableColumnSizeGet(&m_ATitleCells[0].Table,
0, m_ATitleCells[0].Column - 1, &pt[0]);
ProVectorTrfEval(pt, Matrix, pt);
OS << L"ColSize (" << m_ATitleCells[0].Column << L"): " << pt[0] << endl;
Greetings Lars
