Tricks & Tips From the Conference
rmast
There was a tricks and tips session on Monday afternoon. It showed a way to expand the model tree to highlight a selected component that is in a sub-assembly. I cannot figure out what the steps are to do this from my notes. The posted PPT does not have a slide on this technique. Anybody see this or know how to do it? Is it WF5 only?
2 REPLIES 2
Is this what you're looking for? Put this button on a toolbar, then select a model on screen and click this button. The model tree will expand the model that you had selected. This is in WF3.
[cid:image001.png@01CB0EEF.64EA7250]
Hope this helps,
Arnold Collett
rmast
(To:rmast)
Yes. This is it. I was looking under the "All Commands" instead of "View". Thanks.
Roger Mast
Haytools, Round Balers
Project Designer, CAD Coordinator
New Holland, PA
(717) 355-3561
-<">mailto:->
THE ATTACHED FILE, INCLUDING THE INFORMATION CONTAINED HEREIN, IS A CONFIDENTIAL AND PROPRIETARY PROPERTY OF CNH GLOBAL N.V. AND/OR ITS SUBSIDIARIES. ANY USE, EXCEPT THAT FOR WHICH IT MAY BE LOANED, IS PROHIBITED.
