Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Good morning all We are preparing to move to WF4 M092 - I have been testing this in combination with EFX 6.0. I appreciate the advice to go to a later build but I'll save you the time, M092 has been blessed, so M092 it shall be...
When we install Pro on the clients, we do an xcopy of the files off a file server and I want to cull out everything I don't need before load up all the clients. I have noticed that this build includes the Demo version of Manikin with icons appearing in assembly mode. We use another software to check reach and other ergo features and I would like to remove manikin altogether. I did the brute force tactic and searched the loadpoint subdirectory for *manikin* and deleted all the files. All the Icons disappeared and Pro seemed to run just fine, however the EFX pulldown menu also disappeared when I went to assembly mode. So therefore I need to be a bit more surgical,
Can someone tell me which files to delete to disable Manikin?
Thanks!
Martin T. Brown Design Specialist Facilities, Science & Technology Merrick & Company 1099 Commerce Park Drive Oak Ridge, Tennessee 37830 Direct: 865-241-4642 www.merrick.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
