Un-Set config.pro option?
akelly
Is there a way to un-set a load-point config.pro setting from the home/start-in config.pro? I want to remove something that shouldn't be in the load-point config.pro. The specific option doesn't have a default value, so I can't brute-force a NULL/empty/nothing/unset value.
Specific problem: load-point config.pro specifies pen1_line_weight which *might* be affecting my plots. I can't edit it out of the load-point config.pro because our launcher overwrites it every time.
Using WF5
Andrew Kelly, P.E.
Design Engineer
Honeywell Sensing and Control
2080 Arlingate Lane
Columbus, OH 43228
Office: 614-850-7818
Toll Free: 800-848-6564
Fax: 614-850-1111
andrew.kelly@honeywell.com<">mailto:andrew.kelly@honeywell.com>
1 REPLY 1
You could try to set it in a pen table fil [.pnt] like
pen 1 thickness .035 cm; color 0.0 0.0 0.0
Maybe that will overload the configuration option.
/Bjarne
