Unable to remove a drawing template
LR_14430187
2-Explorer
I am after some advice please. I am fairly new to using creo (have used solidworks, inventor and rhino in a previous role), I am trying to remove a template from the list on creating a new drawing. I have navigated to the folder where the templates are saved and this particular template isnt in there to remove, yet it is showing in the list as a n option. Any idea where it would be or why it is still showing?
Thank you!
4 REPLIES 4
Thank you!
it looks like web has problems with attached pictures. Please include them into text pf your reply using Copy&Paste functionality.
Martin Hanák
@LR_14430187 wrote:
please check setting of following config.pro options:
start_model_dir
template_drawing
See also https://support.ptc.com/help/windchill/cloud/r12.0.2.0/en/index.html#page/Windchill_Help_Center/ProEWCIntegAHProEConfigOp.html page.
Martin Hanák
Hi @LR_14430187 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
