For a while back I've created an assembly and annotation drawing in creo express 4 and saved it as a bundle.
Because I've had some problems with my computer I decided to re-instal Windows 7 (64).
Now I've installed Creo Express 6 and I've modified the assembly and want to update the annotation drawing.
When I'm trying to save it as a bundle I'm getting an error:
Then I klick 'OK' and get this massage:
I've googled this and the only topic on this issue is this one:
http://communities.ptc.com/thread/36422
Unfortunally there is not realy an awnser to the problem. Does anyone have the solution?
I've tried to make a new drawing from a new model
I've tried changing the destination folder
I've cleared the 'temp' directory but it didn't make any diffrence.
Big thanks for the reply's
well I don't know what the problem was bud it works again.
I've re-installed windows again bud now formated every partition.
Probably some hickup on the harddrive who knows.
Isn't there anyone with the solution??
I don't think I am the only one withe this problem because I tried the program on an other computer and I'm getting the same error.
Or is there an other way to save a annotation drawing??
